Viktor's finial
Greolt
Model of CNC Machine: UCCNC Router, Plasma, Laser
Viktor's finial
Post by Greolt »
gravirozo wrote: greg last weekend i made a few couple of these... but still i have no ready rotary head that fit under the gantry.... so if you feel you could help me out again, like with table leg that would be great...
Viktor
How did you cut these, if not on a rotary axis?
Here is my attempt using your model and cutting it on the 4th axis. It deserves a better bit of wood.
Sorry for the poor picture. Can't find my camera and this was taken with a mobile phone.
Greg
gravirozo
Re: Viktor's finial
Post by gravirozo »
greg
million thanks... came out good...
greg, i started with a blank, corners were cutted off... so i started of a close round, an octogon shape...
first i made two """jig""" on the table
nailed one endblock fixed on the center, measured by caliper...
the other side i just nailed on center with one nail... and aligned in the jig, and fixed with more nail
first z level roughing
second rough made between parts a rounded 1/2 inc dia auxillary """shaft"""
made a center jig
second rough on other side too
finish passes eight times
for toolpathing i used a ""prism""" in aspire... it showed 1/8 of the model...
viktor
Gc3
Re: Viktor's finial
Post by Gc3 »
Nice work as always Viktor. Thanks for posting.
Gene
gravirozo
Re: Viktor's finial
Post by gravirozo »
thank you gene
greg... some more pic... it shows the gap under the bridge-gantry is exact 4 inch...
i was thinking on to raise the gantry, but the z movement around 2 1/2 inch only 65 mm approx... so after raising the gantry, i could work on the Z and Y axis too..
last week i made some plates for the rotary i started... i had some scrap aluminum...
this week i just ordered some machinevise and other stuff for my milll... so it might help me more..
it will work okay with my older router..
i made about 1:5 ratio because of the small motors..
viktor
Greolt
Re: Viktor's finial
Post by Greolt »
Viktor
That is ingenious how you used hexagonal holding blocks. Six sided 3D machining. Very clever.
I am interested in how you went about producing the model.
The underlying egg shape and the base is simple, but how did you go about modelling the leaves or petals?
Greg
gravirozo
Re: Viktor's finial
Post by gravirozo »
i made one leaf of all row, and multiplied them in accutrans...
also i used a """prism"" to see in 3d what size need of petals...
the picture shows in aspire before sculpting the first petal...
viktor
dhellew2
Model of CNC Machine: Legacy Artisan 72 and AVID CNC Rotary
Re: Viktor's finial
Post by dhellew2 »
Thanks Viktor for sharing. You always do great work and seem to find a way to make anything work. Dale
Young = time, no money
Old = money, no time
Dale
fretsman68
Re: Viktor's finial
Post by fretsman68 »
Viktor, just amazing stuff!
I also wanted to comment and thank you for always adding your knowledge and info in great detail. You have taught me a lot with all the input you give on the forum and I appreciate that very much.
Dave
EDIT: Greg, your work is absolutely amazing as always - :wink:
Dave
gravirozo
Re: Viktor's finial
Post by gravirozo »
thank you for comments
thanks to greg to helped me showing this work in both way, with rotary and with ""flipping"" on table..
this type of work works faster with rotary.. the reason i show this method because many user out there, who might can't afford rotary and expenses equipment...
also several type of model that need multiple sidemachining... indexing on sides and calculate separated toolpath for sides... like human figures with arms or similar objects..
in this work, might worth to pointing the petals, as their shape very difficult (if not impossible) in cad.. so i think very reasonable to learn method, combine aspire sculpting-smoothing ability with cad-cam3d...
viktor
Greolt
Re: Viktor's finial
Post by Greolt »
Viktor
I would be very interested to see how you made the leaves.
If I make them and ADD them to the underlying shape, in Aspire it only ADDs in one dimension (Z), which distorts them.
Greg
Gc3
Re: Viktor's finial
Post by Gc3 »
Greolt wrote:Viktor
Greg
...well that is why viktor is viktor!!!
AGAIN
nice work Viktor!
