longworth chuck
splinter
longworth chuck
Post by splinter »
I always ran into the problem of trying to hold finished parts without screws or marks from a chuck i came across this longworth chuck design it works good and simple to make i used cam clamps instead of wing nuts to tighten holds well at low rpm and light work next project to make one for my rotary. splinter
glenn
Model of CNC Machine: home brew 40x20
Re: longworth chuck
Post by glenn »
Hi Splinter,
Nice chuck, how do you center your workpiece?
Glenn
splinter
Re: longworth chuck
Post by splinter »
GLENN, THER IS A HOLE IN CENTER I HAVE A 1/4 PIN IN FROM THE BACK AS THE TWO PLATES ARE TRUNED THE RUBBER STOPPERS SLIDE IN THE GROVE AND CENTERS IT SELF THEN I FLIP THE CAM CLAMPS AND IT TIGHTENS. SPLINTER;
