Here is a trick for making a tapered column in V-Carve Pro...
Use the Fluting Layout Gadget and give it a large number of lines (For a 3.5" diameter column and a 1" ballnose use 110 lines)
Use the Fluting toolpath
For Flute Type choose Ramp Over Complete Length
For Ramp Type choose Linear for a straight taper or Smooth for a curved taper
For Flute Depth enter half the amount that you want the diameter to change by (remember that it is getting machined on "both" sides of the column) Example: if the column is 3.5" in diameter and you want it to taper down to 2.5" in diameter then (3.5-2.5)/2 = 0.5
Try previewing the results using both the isometric and X axis views. Try checking and unchecking the toolpath preview.
Now, where the I come up with 110 for the number of lines? When doing 3D work, a stepover of 10% (or smaller) works well. If I'm using a 1" ballnose bit then a 10% stepover would be 0.1". If I divide the width of the material by the stepover I get the number of lines.
(Material Width)/(Bit Stepover)=Lines
(10.9956/0.1)=110
->Video on the Web
Tapered Column with VCarvePro
- larrybadgett
- Model of CNC Machine: ShopSabre
Re: Tapered Column with VCarvePro
Everything looks more like Aspire versus VCarve Pro
- Model of CNC Machine: CAMaster 508 ATC
excellent randall!! larry the functions of aspire and vcp are the same with the exception of the 3d functions and tool paths.
jim
jim
Larry,
You are correct that I was running the video demonstration in Aspire, but the technique works for Vcarve too. I was not using any of the Aspire features.
- DavidCousins
Randall
Nice video. A perfect tutorial for the VcarvePro users.
Dave
Dave
