Wrapping With Mach
Wrapping With Mach
Postby garylmast » Mon Dec 14, 2009 11:03 pm
This topic has been split and copied from the original as it contains very useful information on setting up Mach. The original topic can be found here ... http://www.vectric.com/forum/viewtopic.php?f=27&t=7255 and started with questions about missing files on the User grpup DVD
Brian
Tony,
I'm still trying to wrap my brain around the concept of wrapping. I loaded the tapered leg file and through tool path drawing section, wrapped the Y value around the x-axis, then saved the toolpathes. Loading the files in Mach 3, although it don't show the display in 3D view, it indeed follows the x-axis. If you view the Mach controller capture jpg, the "Zero 4" controls my index table. First, am I going through the right procedure, and second, do I control the rotation by hand? Thanks.
Gary
garylmast
Re: Missing Files
Postby Tony Mac » Mon Dec 14, 2009 11:24 pm
Have you copied the Rotary Mach3 Postp from,
C:\Program Files\Aspire V2.5\PostP\05-Wrapped\Mach
Up two levels into,
The Wrapped Rotary postp's then appear in the list as,
Mach2/3-WrapX2A ATC(inch)(*.txt)
I hope this might help and any assistance from other Mach3 users would be appreciated.
Tony
Tony Mac
Vectric Alumni
Re: Missing Files
Postby Greolt » Mon Dec 14, 2009 11:39 pm
Gary
To get the toolpath to display in Mach there are a couple of things that must be done.
First is that the rotary axis must be designated A. Your rotary may be B, but Mach can only visually represent A axis toolpaths.
Then in Config/Toolpath you must set "A-Rotations enabled" and select which axis your rotary is aligned with. X in your case. See pic.
It can be done otherwise but is best to have Z zero at the centre of rotation.
And set the Z DRO in Rotation Diameters" to near zero on the settings page. Not zero, or the "Use Diameter for Feedrate" will not work.
Greg
Greolt
Model of CNC Machine: 900 x 750 2hp UCCNC Router & others
Re: Missing Files
Postby garylmast » Tue Dec 15, 2009 12:42 am
Thanks Tony and Greg,
After your suggestions, everything seems to work great. It also helped when I enabled A motor output.
Gary
garylmast
Re: Wrapping With Mach
Postby cleenrmn » Wed Dec 30, 2009 11:54 pm
ive been play with new realse ive done everything on this thread and my mach3 keeps showing x or y values go to a and show up on mach like screen shot what am i doin wrong im sue its just a setting
cleenrmn
Postby Greolt » Thu Dec 31, 2009 12:51 am
I may be able to help but don't understand your question.
Can you try to explain it a bit.
Greg
Greolt
Postby cleenrmn » Thu Dec 31, 2009 1:01 am
hi greg im trying to get the wrapping thing down i draw in aspire and wrap as explained in tuts and when i send to mach 3 it shows up as shown on screen shot a axis shoud be off and y and a are on it shows x or y depending on how i drew it in aspire is offim not excatally sure how to word it it says x or y values output to a
cleenrmn
Postby Greolt » Thu Dec 31, 2009 1:13 am
Are you saying that the toolpath view in Mach does not look like you expect?
Greolt
Postby cleenrmn » Thu Dec 31, 2009 1:23 am
sorry to be abother but when you start the code in mach my x za avis moves cr yza axis move but next screen shot of another post on this thread his x y z axis moves a dosent show movement
cleenrmn
Postby Greolt » Thu Dec 31, 2009 5:12 am
Sorry, but I just don't get what your question is.
Greg
Greolt
Postby kilrabit » Thu Dec 31, 2009 1:49 pm
Lets see.....
You are wrapping X around Y. In Mach open your toolpath config, choose the Y axis as axis of rotation, instead of X axis.
In Greg's above post he is wrapping y around x, and that is why he has the x as axis of rotation chosen.
Try that and see if the X axis will read instead of the A axis in degrees.
kilrabit
Postby cleenrmn » Thu Dec 31, 2009 2:48 pm
it does the same thing except y shows no movment im sure this is something simp;e maybe a mach setting? thanks ;Mike
cleenrmn
Postby dewalt58 » Fri Jan 22, 2010 3:30 am
Is there a way to jog the A-axis in Mach3, making the A-axis stepper rotate?
AL
Always looking for a different way of doing things!!!
dewalt58
Postby ManitobaKeith » Fri Jan 22, 2010 3:40 am
I believe you can by pressing TAB and then use 4+ or 4- buttons.
Keith
It is not only what we do,but also what we do not do,for which we are accountable-Jean Moliere
ManitobaKeith
Postby Greolt » Fri Jan 22, 2010 3:51 am
You can also set keyboard keys to jog A axis.
Goto, Menu/Config/System Hotkeys, and set your choice of A axis jog keys.
Greg
Greolt
Next
