Wrapping 3D all the way around a cylinder
PaulCNCMann
Post by PaulCNCMann »
Been playing allot and Can't seem to figure out how to wrap 3d objects all the way around it just wants to do the top 180
Any help?
Paul
Paul Mannhardt
Greolt
Model of CNC Machine: UCCNC Router, Plasma, Laser
Re: Wrapping 3D all the way around a cylinder
Post by Greolt »
Paul
You need to get your head around the relationship between the size of the layout and the eventual circumference.
There are quite a few examples in this thread, http://www.vectric.com/forum/viewtopic.php?f=35&t=6449
And for wrapping a 3D model 360 degrees, look at this particular post, http://www.vectric.com/forum/viewtopic. ... 301#p44301
These examples were wrapped with CNCWrapper, but it is exactly the same thing as we now have inside aspire.
Greg
PaulCNCMann
Thanks Greg,
I need to "wrap" my head around witch axis I'm actually wrapping..... This was the source of my confusion.
Thanks for the info and help.
Paul
Paul Mannhardt
ManitobaKeith
Post by ManitobaKeith »
One thing Greolt never mentioned.
If you need a little Circumference calculator like the one in CNCWrapper, go to Andrews site CNCWrapper.com and there is a free one there. Just click on "Freeware"
You can just extract it to the Gadgets folder in Aspire and then the next time you start Aspire, you can select it.
Keith
It is not only what we do,but also what we do not do,for which we are accountable-Jean Moliere
Kubotaman
Post by Kubotaman »
I certainly don't want to sound stupid by where is the "Gadgets" folder in Aspire? I can't find it.
Randy
Post by Randy »
\Program Files\Aspire V2.0\Gadgets
Slowly I turned...
Randy
ManitobaKeith
Of course to have the "Gadgets Folder" you have to have the "Upgrade Patch" installed.
I renamed my Aspire folder to Aspire 2.5 and then changed my shortcuts etc.
Keith
Paul A
Model of CNC Machine: Shopbot-Laser-Custom CNC & Indexer
Post by Paul A »
PaulCNCMann wrote:Been playing allot and Can't seem to figure out how to wrap 3d objects all the way around it just wants to do the top 180
Any help?
Paul
Paul,
You can machine a 3D surface around a cylinder but you cannot machine all the way round a 3D object.
You can machine a 3D object from 4 sides.
Snap_2009.12.06 18.03.05_001.tif
(100.08 KiB) Downloaded 156 times
Paul
If you only have a hammer, everything looks like a nail.
http://www.fretworks.co.uk/
Greolt
Post by Greolt »
Paul (above) has made a good point.
I did not pick up that Paul (OP) was perhaps referring to a full 3D model.
What has been included in the latest version of Aspire is a method to "Wrap" an XYZ toolpath to a rotary axis via a post processor.
Please don't be confused, this is a long way short of full 4 axis CAM where you can produce a toolpath from a full 3D model. Like for instance a chess piece.
Wrapping is nothing new, we have always been able to do this via a variety of methods, however we now have a post processor included in Aspire.
This is just the first small step toward the day when Vectric will have a proper 4 axis CAM program (are you reading this Brian? :) )
However, even though the wrapping method is quite limiting, there is still a useful range of things we can do with it.
I look forward to seeing, over time, the collective ingenuity of this forum coming to bear on this wrapping method and the work that will be produced.
Greg
wjfiles
Model of CNC Machine: Small Custom built CNC Router
Post by wjfiles »
Just a thought but could it be possible to get close by using some crafty
art work with the modeling tools in aspire and wrapper to create a 3d Model.
wjf
