Profiles and Spirals with a 3/4" Barley Twist bit
Postby Rcnewcomb » Mon Aug 12, 2019 4:43 am
These are 13" 2x2 pine scraps that came off a packing crate. I used a Magnate 7558 3/4" Barley Twist bit.
15K RPM, 60 IPM, 0.1" pass depth
Depth of cut for these pieces ranged from 0.125" to 0.1875"
I did not use a rounding toolpath at all since the profile and spiral toolpaths overlapped each other.
The profile columns took about three and a half minutes. (0:03:30)
The spiral column took about five and a half minutes. (0:05:30)
Re: Profiles and Spirals with a 3/4" Barley Twist bit
Postby Rcnewcomb » Mon Aug 12, 2019 5:50 am
Here is a video of the spiral being carved: Spiral Barley Twist Column
Postby dhellew2 » Tue Aug 13, 2019 6:10 am
More variations of the barley twist. Dale
Dale
dhellew2
Postby Rcnewcomb » Sun Aug 18, 2019 12:42 am
used a 1" barley twist. around 10 minutes of machine time.
Postby Mark's Wood Chips » Sun Aug 18, 2019 2:59 pm
dhellew2 wrote:More variations of the barley twist. Dale
Both of you guy's barley twists are intriguing. I'm struggling with 4th axis work and I notice quite a bit or deflection near the center of the run on smaller diameter parts. Dale's walking sticks are beautiful and I would like to try to make something similar. Dale, could you post a photo of how you deal with deflection on long, narrow parts? Any other hints like tool bits and depth of cuts would be appreciated.
Mark
Mark's Wood Chips
Model of CNC Machine: ShopSabre 23 with Rotary
Postby mark-s » Sun Aug 18, 2019 3:12 pm
Really like the walking sticks.
Nice work fellas.
mark-s
mark-s
Model of CNC Machine: diy 4 X 4 CNC Router
