Cabriole leg machining
Postby Lee Wood » Tue May 14, 2019 10:49 am
Hello Vectric Community
I have recently bought a Chinese CNC with a 4th axis and have been trying to machine an STL file of a cabriole leg. My problem is I have no idea what to set as the model thickness since it not even on all sides. I have tried to watch videos on you tube but this step is always missing. How do i go about it?
Charles.
Lee Wood
Model of CNC Machine: EA-1325SVR
Re: Cabriole leg machining
Postby TReischl » Tue May 14, 2019 1:16 pm
Pay attention when you import the stl file.
The import screen will show you the length and diameter of the model and allow you to scale the model.
http://www.tedreischl.com
Low Profile CNC Router Vise
Postby Lee Wood » Tue May 14, 2019 6:14 pm
Hello TReischl
Thanks for your response. On importing the stl file the values indicated were length 391.427mm which i set at 400mm while the diameter indicated was 99.221mm which i used 100mm for the material. The others were Gap outside model 0.043 and the model thickness set itself at 49.608 while the model plane was 0.349mm. I used a 12mm ball nose for roughing but I stopped the roughing process when i realized it was almost roughing to the center. My guess was because of the Model thickness but I have no clue what to set it.
Charles.
Lee Wood
Postby TReischl » Tue May 14, 2019 8:49 pm
Not sure what you are making?
Some models do not have material left around the centerline, those are a problem.
One thing you can do is model up a small cylinder, say 6mm in diameter and see if that surface shows through on your model. That will tell you a lot about where your model is in relation to the centerline of the rotary.
Other than that, you might want to post a screen capture of what your model looks like. BTW, what is your toolpath preview showing you?
Postby Lee Wood » Wed May 15, 2019 12:18 am
Hi TReischl
This is the stl file I've been working on.
Charles
Lee Wood
Postby Rcnewcomb » Wed May 15, 2019 12:50 am
Oh, I know that leg well. It takes some fiddling to get the model adjusted so the centerline is covered.
Under Help/Video Tutorial Browser look for the video Rotary Import & Unwrap Full 3D starting at the 4 minute mark.
Postby Lee Wood » Wed May 15, 2019 8:31 pm
Hi Rcnewcomb,
I have now watched this tutorial and its very similar to what I need to do. I will practically do it and post the results. Many thanks.
Lee Wood
Return to Wrapped Rotary Machining
