Rotary with barley Twist
Postby Rcnewcomb » Sun May 12, 2019 1:31 am
Everything was cut in under 15 minutes including the rounding of the 4"x4". Most were done in about 12 minutes. The pieces are 13"-14" long and cut from Home Depot redwood 4"x4"s. The bit was a Magnate 7551 1" Barley Twist with a 0.5" cutting length.
Re: Rotary with barley Twist
Postby Rcnewcomb » Sun May 12, 2019 1:37 am
A few earlier shots of the first cuts with the Magnate 7551 1" Barley Twist bit. Very nice finish straight off the machine.
Postby Rcnewcomb » Sun May 12, 2019 1:51 am
Here is a 40 second video of rounding the 4x4 with a 1/2" end mill. ->YouTube Video
Postby SteveNelson46 » Sun May 12, 2019 2:00 am
Nice job Randall. I was trying to make the round over part of the cut meet exactly half way so it formed a symmetrical dome. It can be done but the depth of cut, z-zero, and the diameter of the blank have to be set exactly. If any of the settings are off by even a couple of thousandths of an inch the round-overs will have a ridge or flat spot. Vectric tech support help me work it out.
SteveNelson46
Postby mtylerfl » Sun May 12, 2019 2:21 am
SteveNelson46 wrote:Nice job Randall. I was trying to make the round over part of the cut meet exactly half way so it formed a symmetrical dome. It can be done but the depth of cut, z-zero, and the diameter of the blank have to be set exactly. If any of the settings are off by even a couple of thousandths of an inch the round-overs will have a ridge or flat spot. Vectric tech support help me work it out.
Hmmm. Glad they helped you sort that, Steve, but I could have sworn you mentioned in your original post/thread you had already confirmed your z-zero settings for accuracy, adjusted cut depth, had accurate diameter, vector spacing, etc.
Was there anything Tech Support said other than what you (and us) had not already thought of?
carvebuddy.com
Postby mtylerfl » Sun May 12, 2019 2:24 am
Randall! All those rotary examples look fantastic! Are you bringing some to Denver?
carvebuddy.com
Postby Rcnewcomb » Sun May 12, 2019 2:33 am
That is what I am hoping for.
Postby sawmiller » Sun May 26, 2019 12:21 pm
on the roundover video i like how its doing the rounding in one pass, did you change the depth of pass ?
In the heart of Tn
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Postby Rcnewcomb » Sun May 26, 2019 8:41 pm
On the roundover I use 0.5 pass depth with the 1/2” bit because I use a 20% step over. So it is mostly side cutting a narrow strip.
Return to Wrapped Rotary Machining
