Is a new Linuxcnc translator needed?
Postby Chris401 » Fri Feb 01, 2019 1:52 pm
Anyone setup a Linuxcnc translator. Vcarvepro seems to be outputting XYZ with all linear movements rather than XAZ when I specify and X parallel rotary axis. I can deal with this with multiple ini files in linuxcnc for different diameter parts but it seems inconvient compared to having. Now this is my first attempt to use a rotary axis so I might be missing something. Any advice from Linuxcnc users?
Chris401
Model of CNC Machine: Self designed gantry machine
Re: Is a new Linuxcnc translator needed?
Postby 4DThinker » Fri Feb 01, 2019 7:01 pm
The switching of axis directions is up to the post processor used. I do a lot of rotary work using LinuxCNC and a post processor provided by the company I bought my CNC from. It maps X to A though, and you need one that maps Y to A. What brand of CNC are you using?
4DThinker
Postby Chris401 » Fri Feb 01, 2019 7:34 pm
Ah, I am afraid I am on my own for support. Designed and constructed myself. I am a retired mechanical engineer/aircraft engine designer but wife wife just never understood the need for such a machine so making my own worked better.
Chris401
Postby 4DThinker » Sat Feb 02, 2019 6:34 pm
I've uploaded a "wrap Y to A post processor" you might try. It should convert all your Y direction movements to A (rotary) movements. As you've made you own CNC I can't guarantee if it will work with your rotary axis/controller, but it is for LinuxCNC.
Emc2 Wrap YtoA(inch).pp
(4.37 KiB) Downloaded 60 times
In VCarve or Aspire you can click on File>Open Application Data Folder... to see the PostP folder you should copy this to. You'll need to re-open the program to get it to show up on your post processor list.
4D
4DThinker
