Rotary and Tiling
Rotary and Tiling
Postby mfirlott » Wed Nov 21, 2018 8:21 pm
I'm not near my computer or CNC but just had a thought and was wondering if it was doable.
Does Tiling a job work with the rotary?
I want to design a staff in Aspire for machining on the rotary axis BUT as I only have a 3 feet rotary, so can I TILE my full 60" design in Aspire, output the 3 tile files at 20" apiece, then run each individual 20" section of the staff on the rotary?
I did do this before but as 3 separate files...not as a tile job but was thinking that if I did it as one job, tiled, I'd get a better view of the finished piece in Aspire viewing. Also alignment between each tile would ensure a better fit...was not that good last time when I did it as 3 separate files.
Want to limit each piece to 20" to reduce the flex when cutting and was thinking that tiling would ensure better alignment and better viewing of the job in Aspire.
Thanks...
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
Epilog 45watt Helix Laser
mfirlott
Model of CNC Machine: Stinger 1 (2014)
Re: Rotary and Tiling
Postby mfirlott » Sun Nov 25, 2018 4:21 pm
OK...just to close this thread...I finally got to my computer and tried it.
For those who may have been thinking about this...tiling option is not an option when choose the rotary setup.
Too bad....
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
mfirlott
Postby IslaWW » Mon Nov 26, 2018 12:01 am
Mitch....
You mean "by pressing the tiling button". Of course it can be done.
What if...…
You selected a single sided job with the same exact job size that the rotary would use.....
Try the tiling feature
Try using a rotary postP :)
Ill leave the rest to your imagination
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby mfirlott » Mon Nov 26, 2018 10:38 pm
Thanks Gary.
When I chose Rotary Job Setup, create a test object (staff), then press Tiling button in Toolpath, it gives error.
But I do like your "imagination" idea and will give that a try. Sounds like that would work. Thanks for that.
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
mfirlott
