Tapered Octagon
Tapered Octagon
Postby Rcnewcomb » Fri Oct 19, 2018 2:06 am
I created a tutorial on how to create a Tapered Octagon.
You can download the Aspire file at: TaperedOctagon.zip
TaperedOctagon.pdf
(579.02 KiB) Downloaded 111 times
Re: Tapered Octagon
Postby mtylerfl » Fri Oct 19, 2018 2:22 am
Nice of you to do that tutorial for us, Randall!
Re: Tapered Octagon
Postby Mark's Wood Chips » Fri Oct 19, 2018 6:23 pm
Thank you for the detailed pdf. I'm just beginning to learn rotary and I need all the help I can get.
Mark
Mark's Wood Chips
Model of CNC Machine: ShopSabre 23 with Rotary
Re: Tapered Octagon
Postby Rcnewcomb » Fri Oct 19, 2018 7:11 pm
It is also available as a web page here: www.222artisans.com/TaperedOctagon.htm
Re: Tapered Octagon
Postby dwilli9013 » Fri Oct 19, 2018 7:29 pm
Thanks Randall,
Should come in quite handy. :lol: :lol:
D-Dub
Dwayne
Dwilli
dwilli9013
Re: Tapered Octagon
Postby highpockets » Fri Oct 19, 2018 9:00 pm
Thanks for sharing Randall. Haven't gotten into rotary yet... Of course I need a 4th axis first... :D :D :D
Re: Tapered Octagon
Postby davemartin88 » Mon Feb 04, 2019 12:21 am
Thanks Randall for this tutorial. I'm wanting to try and make some wooden wine glass stems for a friend who wants some custom wine glasses for a wedding gift. I'll engrave the glasses with my laser as well. The first picture is the design I came up with using Fusion 360 to show my friend the idea. I had no idea how to start in Aspire but after seeing this post, I've started working on a design, here's a preview of where I'm at. I'm thinking that I'll move the stem to my normal lathe to drill a hole for the stem and to turn an indent for the wine glass bowl to fit before using epoxy to set the bowl. Work in progress, thanks again!
davemartin88
Model of CNC Machine: CAMMaster Stinger II
Re: Tapered Octagon
Postby Rcnewcomb » Mon Feb 04, 2019 3:23 am
Keep us posted on your progres!
Re: Tapered Octagon
Postby eph210 » Mon Feb 04, 2019 9:15 pm
I have made wine glasses on the rotary although not octagonal. I used a twisted Reuleaux triangle for the shape.
One thing to be aware of is the strength of the flared base. Because it is mostly short grain construction, if it is made a thin disc it is very fragile and likely to break in use.
Euan
eph210
Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Re: Tapered Octagon
Postby davemartin88 » Mon Feb 04, 2019 11:43 pm
Thanks Euan for the tip, will be careful and might modify the design a bit. While I’m trying to figure out how to actually use my rotary, I decided to 3D print a modified version of the stem from some wood filament. Showed me a couple of areas I may want to tweak in the final version so a fun prototype. I’m waiting to get the a actual wine glass I’ll use for the bowl to finalize the plan.
davemartin88
