calling all rotary experts
Postby ohiolyons » Fri Sep 14, 2018 4:27 pm
OK I've been using Aspire since 2010, but 1 week ago I started exploring Wrapping.
I watched the Rotary Import & Unwrap Full 3D tutorial and it was very useful.
I had an image scanned in as an STL and I imported it into a rotary project and it "looks correct and consistent with the tutorial.
I generate toolpaths and those toolpaths look consistent with the tutorial.
I do the Preview Toolpaths and the resulting image looks like there is a pie shape piece missing from the image.
It looks like the size of the material was too small so it cut it off.
I re-ran it and said make the image fit the material, same result.
I re-ran it and said make the material fit the image, same result.
I assumed there was something wrong with my model so I downloaded a random image from Grabcad and same problem, pie shaped wedge missing from the Preview Toolpath.
Not certain of the size limits for uploading the file so I will get to it.
If it is too large what is the preferred method to make the file available?
Thanks in advance.
CNC in Kettering, Ohio
ohiolyons
Model of CNC Machine: Laguna IQ HHC, 3HP
Re: calling all rotary experts
Postby Rcnewcomb » Fri Sep 14, 2018 4:40 pm
Post it on drive.google.com or dropbox.com and share the link with us.
Postby ohiolyons » Fri Sep 14, 2018 4:50 pm
here is a photo of what is happening. I'm working on the file upload.
ohiolyons
Postby ohiolyons » Fri Sep 14, 2018 4:52 pm
https://drive.google.com/file/d/1hmU8RT ... sp=sharing
I know the model is not water tight. That is why I downloaded a model from gradcad and got the same problem.
ohiolyons
Postby garylmast » Fri Sep 14, 2018 4:53 pm
If you increase the length (diameter) of the model it will close up the missing pie shape (seam of the model). You can go slighter past the edge of the material block and it's not going to hurt anything.
Gary
garylmast
Postby ohiolyons » Fri Sep 14, 2018 5:12 pm
I changed the diameter from 4 to 5 inches, same result.
I changed the diameter from 5 to 6 inches, same result.
It seems like when I selected the option make material fit model it should have solved the problem.
ohiolyons
Postby gregk » Fri Sep 14, 2018 5:26 pm
When you imported the model, how did it look like in the 3D view? If there is a wedge after importing, then increasing modelling resolution and importing again may help. Please also consider sending both your project and STL model to our support team at support@vectric.com so we can then investigate.
Greg K
gregk
Vectric Staff
Model of CNC Machine: None
Postby ohiolyons » Fri Sep 14, 2018 5:51 pm
Vectric staff e-mail sent with links
ohiolyons
Postby ohiolyons » Fri Sep 14, 2018 8:04 pm
just created another stl from Design and Make paint brush
It has the pie shaped problem too.
ohiolyons
Postby ohiolyons » Mon Sep 17, 2018 3:28 pm
Problem solved by Vectric as usual!!! Thanks Vectric support staff, your usual outstanding job.
Turns out I had boundary offsets values from a previous job and that is what caused the pie shaped wedges.
Removed the boundary offsets and poof carves as expected.
ohiolyons
Postby Rcnewcomb » Mon Sep 17, 2018 10:48 pm
Please post some photos of your work. It's always fun to see what others are doing with rotary. :)
Postby ohiolyons » Mon Sep 17, 2018 11:33 pm
I don't have access to a rotary CNC and are in the initial stages of looking in to it. Therefore I don't have any photos to show. Sorry
ohiolyons
Postby Rcnewcomb » Tue Sep 18, 2018 12:03 am
I'd be happy to try cutting a few of your designs if you wish.
Postby IslaWW » Tue Sep 18, 2018 1:09 am
So when you say: "Removed the boundary offsets and poof carves as expected." And then say: "I don't have access to a rotary CNC and are in the initial stages of looking in to it."
Which one should we believe?
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby ohiolyons » Tue Sep 18, 2018 2:18 am
My experience with aspire is that the actual carving looks like the toolpath simulation.
With the boundary offsets removed the toolpath simulations show the model complete.
I really don't care which one you believe I was just updating the forum as to what the Vectric staff told me to do.
If you don't believe me then import a model, add boundary offsets and cut it. Then take the offsets off and cut it and report your results.
ohiolyons
