I'm needing to do some several production runs of a rotary piece that's 5/8 diameter and 40" long. I tried a piece 20" long and it didn't turn out due to deflection during v-carving due to lack of material strength. I'm thinking of simply making a channel in some MDF that the cylinder can rotate in to help support the piece. Anyone done this before and have any input or tips?
material support
- IslaWW
Re: material support
Ive seen versions of roller steady rests using both bearings and inline skate wheels on adjustable supports
GCnC Control
GCnC Control
Jack Jarvis uses kids roller skates. It is talked about 3/4th of the way down this page: ->CNC Rotary Tutorial
- dealguy11
I have a steady rest that is 2 pieces of notched hdpe plastic that come in from the sides. Don't have a picture handy. Your idea of notched mdf should work.
- Model of CNC Machine: CNC router parts 4x4
I didn't have any mdf on hand so I used some baltic birch I had laying around. It worked pretty good except the stock lifted while v-carving so I may need to fully contain it when v-carving but this is a great improvement over what I had.
here's a video of it running
