rotary 4th axis attachment.
Postby wood400 » Mon Mar 14, 2016 8:10 pm
Hi folks. i am looking at the chinese 4th axis attachment on ebay. ha sanyone any experience of these . I was wondering would one of the 100mm models be capable of machining a cabriole leg of 70mm square and about 800mm long. EG 23/4 square and 30inches long.
Thanks for your help
Alan
wood400
Model of CNC Machine: 7090 cnc router
Re: rotary 4th axis attachment.
Postby IslaWW » Mon Mar 14, 2016 9:22 pm
wood....
a quick search on eBay returned hundreds of results. Yes there were a number that will be up to the task. There are a lot more questions to get answers for before I would buy one tho...
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby anthropod » Mon Mar 14, 2016 9:44 pm
I am very interested in adding a rotary as well.
I see some that say 1:6 Ratio's and ones that says 1:20 Ratios.
Two I am interested are:
http://www.ebay.com/itm/CNC-F-Style-A-A ... Swl8NVXF4S
http://www.ebay.com/itm/CNC-Router-tabl ... SwBLlVOmc4
I have a Geko 540 with one Axis open and I sue Mach3
anthropod
Model of CNC Machine: XZero ViperXZ 30x24
Postby IslaWW » Tue Mar 15, 2016 1:21 am
The reduction should be determined by your max blank diameter and what resolution you require. For example, 6:1 yields .002" step resolution (1/8 microstepping) on a 6" diameter blank. More than ample for rotary wrapped machining up to that diameter. That said, if you are planning on indexed machining, especially off axial center, then the 20:1 may be a better choice. The 20:1 will reduce max rapid speed to around 50-60 rpm, if that is a factor and you may not be able to position it by hand. Are there backlash specs for that 20:1 reduction?
Gary Campbell
IslaWW
Postby anthropod » Tue Mar 15, 2016 3:20 am
I see no backlash specs for the 20:1. Most of what I would be working with should be 2".
anthropod
Postby anthropod » Tue Mar 15, 2016 3:57 pm
What about planetary gears heads? I found a deal on a 4th axis that uses a Thomson Xtrue 100:1 gearhead.
It says that it has a backlash of 13 arc-mins
It comes with a 160oz Nema 23 stepper.
http://www.thomsonlinear.com/website/co ... /xtrue.php
anthropod
Postby IslaWW » Tue Mar 15, 2016 4:33 pm
13 arc minutes is 13/60ths of a degree. This is .00378" backlash at 2" diameter. Unacceptable for may use, YMMV. 100:1 is so much reduction that you may never be able to turn the 4th axis at an acceptable rate.
Gary Campbell
IslaWW
Postby anthropod » Tue Mar 15, 2016 9:16 pm
Im just having a hard time finding a 4th axis to buy to add to my system.
Right now I am looking at three setups:
http://www.ebay.com/itm/261858842965?var=560705631941
http://www.ebay.com/itm/CNC-4th-Axis-Ro ... SwwpdW5mbj
http://www.ebay.com/itm/CNC-Router-Rota ... SwofxUim8K
I'm leaning towards the 50:1 Harmonic Drive.
I will be using 2-3 inch stock and am looking for fine details. I like to make beer tap handles.
Any thoughts?
anthropod
Postby IslaWW » Tue Mar 15, 2016 10:27 pm
If you do go with the 50:1 reduction remember that you must have a controller capable of data output at your required turning speed. A 200 step per revolution (1.8*) will require 10,000 steps per second at 1 revolution per second (60 rpm) which is not fast. You may have to lower rapid expectations to avoid data choke to the 4th axis.
Gary Campbell
IslaWW
Postby wood400 » Thu Mar 17, 2016 5:45 pm
Hi Folks, Thank you for the replies this gives me a help to better understand whats out there.
Thanks alan :D :D :D :D
wood400
