Linux CNC / EMC2 Processors
Postby Askjerry » Sun Sep 14, 2014 11:18 pm
I have a Wells Index CNC (looks like a large Bridgeport) that I am running with Linux CNC. I made two processors, one for X/Y/Z and the other for X/Y/Z/A that has the A wrapped around the X-axis. So far it has tested quite well... and I can run both wrapped and unwrapped G-Code at the same time.
In other words... I can do a 3D job, and I can also do simple cuts, pockets, etc... I can paste G-Gode together and get quite a lot done.
Since I went through the trouble to configure it properly to send all the G and M codes to start the spindle, set the coolant, etc... I figured I would make them available to anyone who wants them.
The 3-Axis, X/Y/Z version: http://rutherford-robotics.com/DLOAD/G-CODE/Wells%20Index%20(XYZ)%20V1.pp
The 4-Axis X/Y/Z/A version: http://rutherford-robotics.com/DLOAD/G-CODE/Wells%20Index%20(XYZA)%20V1.pp
Here is a demo of it doing a complex job: https://www.youtube.com/watch?v=g-5OSW5edEs&list=PL3A9590BD3BD2E76C
I hope you find it helpful.
Jerry
Askjerry
Model of CNC Machine: Multiple
Re: Linux CNC / EMC2 Processors
Postby frank131313 » Mon Apr 10, 2017 3:19 am
impressive ! :shock: :!: very good
frank131313
Model of CNC Machine: biesse rover 30L2
Postby AcBCDN » Tue Apr 11, 2017 7:42 pm
Askjerry wrote:I have a Wells Index CNC (looks like a large Bridgeport) that I am running with Linux CNC. I made two processors, one for X/Y/Z and the other for X/Y/Z/A that has the A wrapped around the X-axis. So far it has tested quite well... and I can run both wrapped and unwrapped G-Code at the same time.
Jerry
Link seems to be problem. :(
AcBCDN
Model of CNC Machine: HomeBuilt
