here is the file
If you look at the picture I'll tell you what mine look like the Home on the top of the picture is all the way to the right and backwards, the word sweet is backwards teews the home at the bottom of the picture is all the way to the left and spelled back wards also emoh please help what it looks like is that you need to pull the picture off and turn it over and lay it back on !
The file I tried to cut !
Re: The file I tried to cut !
Can you post your CRV or CRV3D file?
- Model of CNC Machine: Small Custom built CNC Router
If that is a lithophane you are looking at it from the back.
The rough side is the front.
wjf
wjf
The view you are looking at directly above your post is what the rough surface looks like I have settings wrong somewhere it cut it on backwards.
Either reverse the rotation of the indexer or move it head for toe where it's positioned on the bed of the CNC machine. Gary
In your motor tuning on the cnc reverse the rotation of the A axis.Norm
