Hello All,
It`s bin a time that i posted a problem. The most problems i can find on the forum!!
But this time after many hours reading I really need your help.
It`s probebly a simply solution but im not getting there.
A wooden "klos" (don`t know what it is in english) cut out an 30mm wooden stick.
cut on the x-as, i made the drawing and a picture. "I think you get the drift"
thanks in advance
greetz Juan
Round wooden "klos"
- juan
Round wooden "klos"
- Klosje 80mm.crv3d
- (11 KiB) Downloaded 282 times
- Norb
- Model of CNC Machine: MAXI-C 1530 SE-T-V
Re: Round wooden "klos"
Hi Juan,
Your project can be done in Aspire with a 2 rail sweep. You need to cut your pattern in half to establish the profile of the 2 rail sweep. See attached
Load attached and go to 3D VIEW tab and in the Toolpaths tab (on top) got to 'Toolpath Drawing' and tick 'Wrap Y values (around X axis)
Remember to use your tail stock with this project or else the klosje (whatever that is ) will break off before you finish your project.
- Wrapped Output for- Klosje-.crv3d
- (25.5 KiB) Downloaded 341 times
Norbert
Aspire 4.x, PartMasterCAM Turn, Autocabinets
after hours: Sherline 2010 and 4410
- juan
Thanks Norb, that`s Quick!!
That is exactly what I want.. Now I`m trying to duplicate your moves
first question, how do you know your height in the "job setup" ? that is 94.248mm ?
The width thats easy, the Thickness is 1/2 wooden "stick" diameter, but the height i don`t get it.
thanks!!
greetz Juan
thanks!!
greetz Juan
lengte is gewoon de lengte x-as breedte is y - pie x diameter (3.14xD)
- juan
thanks Piet,
that simpel? hahaha I wil calculate that ... Damn your right!!
Oke I will draw en new "klosje" en try it out
thanks
greetz Juan
thanks
greetz Juan
- Ms Wolffie
Klosje = Bobbin
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Norb
Piet is right but you don't need to do a calculation.
Opening your original file I saw that the job was 30mm in the Y direction hence your stock diameter would be 30mm too.
I then 'halved' your design to be used in a 2-rail sweep and exported it as DXF.
Loading a new session of Aspire I went immediately to (tab) Gadgets > Wrapped Job Setup and entered 30 in the diameter field and the length as per your original job setup.
Then I looked at these wrapped 'job setup' details and made a rectangle of exactly the same size as the job and centered it. Then in node editing I went to each corner and 'cut' the vectors deleting the top and the bottom line of the rectangle. The remaining left and right sides are your 2 rails. Import the DXF file, select the 2 rails and the imported vectors and with a 2 rail sweep you get your klosje.
You see, you can use the formula with pie but I prefer to leave the pie out of the formula and have it with a cup of coffee.
Norbert
