V Carve on a taper
V Carve on a taper
Postby Kubotaman » Wed Oct 12, 2011 5:19 am
Does anyone have any ideas how I can make a taper on the indexer and then V-Carve some lettering? I realize you can taper on the ShopBot program but am confused as how one would V Carve on a taper. I run Aspire. The only way I can think I can do it is to raise or lower the tail stock which really is not a good alternative. Thanks!
Kubotaman
Re: V Carve on a taper
Postby fretsman68 » Wed Oct 12, 2011 2:59 pm
Hi, I do not have aspire, but I believe there's a way to "project" the VCarve onto the 3D surface? Possibly this may be better asked in the Aspire part of the forum?
Dave
Dave
fretsman68
Postby jam1962 » Wed Oct 12, 2011 4:14 pm
If memory serves, you can do it with the Fluting tool.
Jay Morris...
jam1962
Model of CNC Machine: Self built 36x25x7
Postby mikeacg » Thu Oct 13, 2011 4:45 pm
Dave is correct! When you set up the Vcarve tool path be sure to check the box (lower left side) for projecting the path to follow the 3D surface. That's all you need to do!
This is one of the first projects I tried when I got my machine...
mikeacg
Postby dhouse » Sun Mar 22, 2015 12:04 am
Are you using VCPro or aspire?
dhouse
Postby mikeacg » Sun Mar 22, 2015 12:23 am
Wow! This is going back a few years! I had Aspire. This was my first week with my new Stinger and I was trying everything I could think of to put it through its paces.
Again, I would like to remind everyone: Do not use treated wood on your machine unless you are wearing a respirator, eye protection and have incredible vacuum on your dust clearance system. And then ask yourself if you are willing to be sick just to save a few bucks. I used a couple of old treated 4x4s thinking it was just practice and I was saving money. I could have glued up walnut and saved in the long run! This crap messed me up for months - I had respiratory problems similar to walking pneumonia and pink-eye like symptoms with my vision! Not worth it! Trust me!!!
Mike
mikeacg
