Legacy milling machine conversion
Has anyone tried to convert a Legacy Milling Machine to CNC? I would like to add a stepper motor for the 6' models long axis and rotary axis. For starters what size motor/gear box should I use?
- joecnc2006
Re: Legacy milling machine conversion
Gc3m, that's a link to an indexer addon, I believe he was wondering if anyone has convered a legacy mill to CNC.
http://legacywoodworking.com/products.cfm?product=5
Joe
http://www.joescnc.com
Joe
- dealguy11
Legacy sells conversion kits for some of their machines, or they used to. You might try contacting them.
Steve Godding
They use to sell an AC motor with limit switches prior to thier CNC line but not any more. This was a simple start button and it ran to the limit switch. It would be easy to put a NEMA 23 stepper motor on it if I knew the torque requirement. After that the controller part is simple. Yes it is the 1200 series per joes link he placed.
