Undesirable 3D tool path code
Discussions and examples relating to the Design & Carve series for Aspire
Moderator: Todd Bailey
Postby mwpfeifer » Fri Jan 31, 2014 1:02 am
I have been doing a few recessed 3D scenes using the wildlife files from the VectorArt 3D Design and Carve Series and have a somewhat minor issue that I would like to resolve or at least understand. If you review the attach picture you will notice the rectangular flat (just inside of the red squiggly lines) carved during the finish tool path along with the with the 3D Scene. It turns out this flat area is the same dimensions as the material X&Y dimensions I set within Aspire (3.5) when I developed this carving but I can't figure out how it is being included with the 3D scene when the finishing toolpath is generated. Obviously I can sand it out or just run it thru the thickness planer and get rid of it but it is adding to the machining time which is long enough already.
Mike
Grand Rapids, MN
Shopbot BT48 w/spindle
mwpfeifer
Model of CNC Machine: ShopBot Buddy BT 48 Std w/Spindle
Re: Undesirable 3D tool path code
Postby Ronwoodson2 » Fri Jan 31, 2014 1:39 am
When creating your toolpaths, select the vector that outlines the recessed area. and all inside that vector, and that will define the area to carve.
Ron Woodson
Somerset, Ky
Ronwoodson2@aol.com
Ronwoodson2
Model of CNC Machine: Shopbot Desktop Max, 6 inch indexer
Postby mwpfeifer » Fri Jan 31, 2014 2:38 pm
Ron,
Unless I add one there is no vector outline to select so guess that is what I will have to do. Still seems kind of strange to have to do this but not a big problem to include.
Mike
Grand Rapids, MN
mwpfeifer
Postby Ronwoodson2 » Fri Jan 31, 2014 2:50 pm
Mike,
Select the dish component, and-- From the modeling tab, select 'Create Vector Boundary from Selected Component'.
This does it quickly.
Ron Woodson
Somerset, Ky
Ronwoodson2@aol.com
Ronwoodson2
Return to Design & Carve - Aspire
