Losing the insides of some letters when imported.
Discussions and examples relating to the Design & Carve series for Aspire
Moderator: Todd Bailey
Postby GeneMpls » Sat Nov 02, 2013 3:54 pm
I have used a dedicated sign program for 15 years an have a fair proficiency in it (FlexiPro) so I do most of my designing in
that program and export .eps files to Aspire 4. When I do that and try to model the text components I get a result as pictured.
All programs use different terminology for similar functions of course and I am new to Aspire having used Vcarve for a year or
so- but I want to 'compound' the inner line with the outer lines of letters that are pierced- 'A;B;P;R- etc'. I am sure there is a
good way to do this but I am having trouble figuring it out. Thanks Gene
GeneMpls
Model of CNC Machine: PRS Buddy48alpha ,3x4' 130w laser, Wazer
Re: Losing the insides of some letters when imported.
Postby Adrian » Sat Nov 02, 2013 4:35 pm
Hard to say without seeing the actual file but it looks like you're creating a VCarve toolpath with only the outer parts of the letters selected. You need to make sure that, for example, you have the outer part of the B and the two inner parts selected when creating the toolpath.
Postby GeneMpls » Sat Nov 02, 2013 5:35 pm
They were both selected- If i fiddle with it (cutting the insides out of the outsides) I can sometimes get it to work. This was modeled
using the create shape from vectors tool- it doesn't seem to recognize the inner vector? Thanks Gene
GeneMpls
Postby Adrian » Sat Nov 02, 2013 6:35 pm
Not 100% what effect you're going for. I usually don't use the create shape for letters. Looking at those letters I'd do them with a VCarve projected onto the 3D surface.
I can't tell what's going on on without seeing the actual CRV3D file, other people might be able to help more. It might be worth re-posting your question in the actual Aspire section rather than here as not many people read the Design & Carve section as it's meant for support for the Design & Carve add-ons from VectorArt3D rather than general Aspire issues.
Postby GeneMpls » Sat Nov 02, 2013 7:23 pm
When I am doing prismatic letters I do do it in Vcarve with a V bit- but say I wanted soft rounded tops on the letters. That said I think
I figured out the problem. I was building a smaller file to post and imported the same text and it comes in with 2 layers of vectors...
I did not notice that last time and selected both sets of vectors and that seems to be the problem. Thanks for taking some time with
me today- this is why I bought Aspire, the great community. Gene
GeneMpls
Postby ChrisInEstes » Mon Nov 04, 2013 7:45 pm
Hey, a fellow Flexi User! I've used FlexiExpert since it was CASMate. I also do my artwork in Flexi, then export as .eps to VCarvePro. On occasion, I have the same problem you're having. It's usually been 2 vectors stacked on top of each other. Once in a while, for some reason, the export to .eps then import to VCP creates an open vector. So, check for open or stacked vectors on the inside parts.
Chris
ChrisInEstes
Return to Design & Carve - Aspire
