geometry of tool has changed
Discussions and examples relating to the Design & Carve series for Aspire
Moderator: Todd Bailey
Postby oldlogtrucker » Wed Jul 18, 2012 2:15 am
Hello all
I am a total newbie. I am trying to do the Open sign tutorial. I am using the aspire 3.5 software. I keep getting an error message that I have used the same tool twice but the geometry of the tool has changed. What am I doing wrong? :?:
Thanks Kathy
Embroidery - WingsXP
oldlogtrucker
Model of CNC Machine: Cam Master StingerII
Re: geometry of tool has changed
Postby oldlogtrucker » Wed Jul 18, 2012 2:50 am
If it helps this is a copy of my message as well as the file created.
Thanks Kathy
Opentutorial.crv3d
(1.05 MiB) Downloaded 235 times
oldlogtrucker
Postby RoutnAbout » Wed Jul 18, 2012 4:49 am
Kathy,
I've never used a machine with ATC.
But from looking at your file, your attempting to use 3 different tools.
1.25" Vbit assigned to Tool1
1/4" endmill assigned to Tool2
.250 Drill assigned to Tool1 - this conflicts with the 1.25" Vbit
I'm unsure how many tool positions you have on your changer, but if you only have 2, you will need to save the drill tool path separate.
If you have more than 2 positions, you'll need to change either the drill or Vbit to another position.
Hope this makes sense.
________
Don
RoutnAbout
Model of CNC Machine: Old Bot with a Rope Pull Start Spindle
Postby COWBOY1296 » Wed Jul 18, 2012 3:41 pm
Sometime back I made the error of using the wrong post processor. So the question is do you have an automatic tool changer if not then find the correct processor. If you do have a atc then make sure that none of your tools have the same tool number. each tool should have its own number.
Still working on coffee so hopefully this made sense.
COWBOY1296
Model of CNC Machine: SHOPBOT BUDDY PRS 32, 4 FT PWR STICK
Return to Design & Carve - Aspire
