Horse Carriage Sign
Discussions and examples relating to the Design & Carve series for Aspire
Moderator: Todd Bailey
Horse Carriage Sign
Postby myshadowboxes » Thu Oct 13, 2011 2:21 am
Well here is my first western scene design. I actually did the palm tree first using the same design as the welcome sign. Ended up doing the Western Horse Carriage sign for my grandfather. One thing I will point out on the "Honeycutt" sign and it is hard to see here because I did try to fix it. If you look at the "n" you will see that it came in two separate pieces. Not a problem with this look however, the left hand side of the "n" where it looks like an r... the little part that comes off the right was way short from what it cut out in the inlay. I had to actually cut a small piece of wood and glue it onto the left part of the "n" Hard to really explain...
myshadowboxes
Model of CNC Machine: Camaster Stinger
Re: Horse Carriage Sign
Postby RoutnAbout » Thu Oct 13, 2011 2:28 am
Those look excellent. I like the way you've profiled them instead of leaving in a square blank.
And your right, I didn't notice the 2 piece "n". Nice recovery.
Roll of Honor <-- Never Forget
________
Don
RoutnAbout
Model of CNC Machine: Old Bot with a Rope Pull Start Spindle
Postby Bob Reda » Thu Oct 13, 2011 11:02 am
Nice ones, I didn't notice the "n" either but I know what you are saying, I'm doing a inlay on the corn hole game board and it did it in both the male and female section. I'll post when I'm done. Maybe this is something that vectric should look into. It only happen on this one piece and I went back and checked it and it was good on the screen.
Bob
Bob Reda
Postby Penman » Thu Oct 13, 2011 11:13 am
They came out very well and in my opinion look great.
Found the problem with the n, but only after you had pointed it out. Good
recovery though.
Roger.
Penman
Model of CNC Machine: Shopbot B 32 Alpha
Postby olf20 » Fri Oct 14, 2011 12:17 pm
Very nice job!! I also like the way you outlined the
signs.
Did you get the palm trees and western wagon from
Vector Art 3D?
olf20 / Bob
[color=#8000BF]Heat with corn, Mach3, Bridgeport clone, VcarvePo, Photo VCarve, Craftsman Wood Lathe[/color]
olf20
Postby myshadowboxes » Fri Oct 14, 2011 2:15 pm
The palm trees came from the first Aspire disk I think...i am at work and can't check. The carriage came from the western disk...i really wish I had more time to do more.
myshadowboxes
Return to Design & Carve - Aspire
Users browsing this forum: Google [Bot] and 1 guest
