Mach 2 Hot Key Configuration
I would like to know how to set the 999 Hot Keys in Mach Hot Key Configuration, they seem to be mixed up. They need to be 999 and they appear as different numbers, is there a way to reset them. Thanks, Jim.
Re: Mach 2 Hot Key Configuration
If I am reading correct, you want to set them back to 999 which means no key is set.
I don't believe there is a built in method to do this.
Maybe a question on the Artsoft forum will have a solution.
Sorry I can not be more help.
Greg
Greg
