I am using Aspire 2 on a Shop Sabre (WinCNC controller)
I want to be able to slow the feed rate down as the bit comes to a corner, and then speed it up after it changes direction, to help minimize the side force, so that the bit doesn't push the material sideways, thus breaking the vacuum, which allows the part to move. I can't see anything in Aspire to do this. Is there some adjustment I can make in the post processor file to accomodate this?
Cornering speed
Re: Cornering speed
hello
what you asking for, that is the control software "todo"...
i don't know wincnc....
in mach the continous velocity has an optin, as you can set a minimal angle, and the program slow down to zero on those corners...i mean all corner <90, sharper than 90 deg, if it has been set for 90 value...
you might need to read trough the user guide of your controlprogram, the vectric programs are generate only g-codes and those has no any effect on your controlsoftware...
i hope it helps you
thanks
viktor
i hope it helps you
thanks
viktor
Re: Cornering speed
On WinCNC I believe this is controlled through the look ahead and the accelerator factor. If there is a WINCNC.INI file look in there for settings.
- Model of CNC Machine: CAMaster 508 ATC
Re: Cornering speed
in your wincnc.ini file there is a comand called smoothing mine is set at 20, do you have servos or steppers and can you copy and paste your ini file here?
this is a generic file from a new seat of wincnc
the setting relation ship between a (axcelleration) in the axis spec and r (rate)
are the culprit's
[X Axis]
axisspec=p0 s1 d1 r500 o1 e1 a1000
axisvel=r1800 f800 s50 m400 h1800 c10
[Y Axis]
axisspec=p0 s0 d0 r500 o1 e1 a1000
axislo=p3 b5
[Z Axis]
axisspec=p0 s2 d2 r100 o1 e1 a500
axisvel=r100 f50 s5 m20 h100
[W Axis]
axisspec=p0 s3 d3 r100 o1 e1 a500
jim
are the culprit's
[X Axis]
[Y Axis]
axislo=p3 b5
[Z Axis]
[W Axis]
jim
Re: Cornering speed
the manual is online at wincnc under support if not i have it
jim
jim
Re: Cornering speed
Thanks! I found it in the ini file, made some adjustments, problem solved!
