Computer crash
Computer crash
Postby lloydca » Sun Aug 25, 2019 7:08 pm
i'am having a problem, after computer crash. The spindle can be turned on using keyboard control F6 or button in the software, but won't turn on using MO3 command as a G code command. Pretty sure I just don't have something set right, but can't figure out what.
Mach 3: Version R3.043.062
spindle uses PMW using a Leafbay 77 3/4 controller card
Any help pointing me in the wright direction would be helpful.
lloydca
Model of CNC Machine: LT-6090 cnc router
Re: Computer crash
Postby Leo » Sun Aug 25, 2019 8:35 pm
I don't know how you are generating the code but m - oh - 3 MO3 will not work
The correct code is M - zero - 3 M03 "should" work if all is well in your machine.
www.leosworkshop.com
Leo
Re: Computer crash
Postby lloydca » Mon Aug 26, 2019 1:44 am
Sorry I'm using M03. TYP. line reads
S12000M03, to set speed and start the spindle, But for some reason the spindle won't start. If i run a G=code file the XY&Z axes move just no spindle.
lloydca
Re: Computer crash
Postby ezurick » Mon Aug 26, 2019 6:23 am
I am unfamiliar with your machine and setup. I have a Chinese 6040 machine and I had a similar situation which everything was working execpt the spindle would not turn on. It happened after I had a slight accident and a fuse popped in my controller. Apparently somehow I lost one of the settings in the controller itself. I followed the directions of setting the controller's codes and presto... worked again. Not sure this will help, but it is worth looking into....
~ Ed
ezurick
Re: Computer crash
Postby ger21 » Mon Aug 26, 2019 12:56 pm
A lot of people have issues with the M3 macro becoming corrupt and not working. You might want to try deleting it and creating a new one.
I don't have a copy of Mach3 handy, but I think the macro is just:
DoSpin(CW)
(Check before deleting it.)
ger21
Re: Computer crash
Postby lloydca » Thu Aug 29, 2019 3:04 am
Okay everything is up and running. Special thank to ger21.
No script in M03 or spindle speed. I remember skimming through what each M code is used for, but don't remember every reading anything about being able to edit the macros. Guess I just thought they magically made stuff work. You all are awesome and thanks for the help.
lloydca
Return to Control Software related questions
