dhellew2 wrote:Have you registered you copy of Mach 3?
The unregistered version has a code line limit.
Dale
Ha, probably not that. I doubt you could cut for 13 hours on that limit.
Mach 3 can be a finicky beast. Some versions/sub versions are better than others, but all have bugs. I can't remember which version I'm using, but mine has a bug where if you try to run from a specific line of code instead of the beginning it will
sometimes drive the into the material/spoil-board. I haven't found the trigger for this, but it has brought a tear to my eye and a lightening of my wallet on occasion.
Add to that the odd glitch with my ethernet smooth stepper, Windows locking up, or random hardware failure, and there is hardly a day that goes by that something doesn't go wrong. Just having typed that, it is no wonder I'm balding.....
