Thanksgiving wreath slows down
Postby auga » Tue Jul 04, 2017 8:33 pm
I have cut many many to my CNC with no issues.
So I using the thanksgiving wreath to cut out to tinyg (MM). I was about 280mm X 280mm in size.
rough cut with no issues. The final has about 500,000 lines of gcode. It starts at about 20 minutes in it nearly
stops. Only moving about 2 mm every 5 minutes. So I killed the process.
Then made a smaller test of about 175 mm X 175mm.
The rough cuts fine.
cuts fine about 45% of the way. Has about 240,000 lines of gcode.
At about 105,000 lines in nearly stops. Takes 5 minutes or so to move 2 or 5mm.
Any thoughts?
auga
Model of CNC Machine: TinyG - Homemade
Re: Thanksgiving wreath slows down
Postby Adrian » Tue Jul 04, 2017 9:33 pm
Memory buffering issues perhaps?
Postby ElevationCreations » Tue Jul 04, 2017 9:59 pm
I concur with Adrian, sounds like a memory buffer issue on your computer or control program. Which gcode sending program are you running? If you are using Chilipepper, it has a 5MB limit which forced me into other programs. For a sending program, I recommend Intelli-Gcode from Software Redefined.
ElevationCreations
Model of CNC Machine: Shapeoko SO3 XXL & SO3
Postby highpockets » Tue Jul 04, 2017 10:10 pm
is the gcode file on your hard drive or a thumbdrive?
Postby auga » Tue Jul 04, 2017 10:13 pm
I using Universal Gcode Sender on Linux on the Raspberry PI 3. Unfortunately the Intelli-Gcode looks like its GRBL only.
I sent some larger gcode files at 125 - 200K with no issues. Never had a memory buffer issue.. Not that it could not be a memory
issue.
auga
