New cnc user software issues. (using cut2d with 6040z)
Re: New cnc user software issues. (using cut2d with 6040z)
Postby dwilli9013 » Mon Feb 20, 2017 10:06 pm
Your rapid feed rate may be set to high as well. If the move consists of both the x and y axis having to move at the same time the inertia may be a bit too much.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby Leo » Tue Feb 21, 2017 12:00 am
Video is great - helps a LOT.
The noise when the machine hangs up is losing steps.
I think you may need to adjust the accel and decell. That is the speed that the axis ramps up and ramps down as it changes direction. If is tries to get up to speed too fast is chatters and hangs up. It that time it looses steps then everything is out to lunch.
You may also want to be sure that all the slides are running freely and smoothly. You don't want anything too loose either.
Some lubricant certainly doesn't hurt either.
www.leosworkshop.com
Leo
Previous
