Mach & Problems with Other items such as a dust collectoion
Postby Roskrow » Sat Oct 29, 2016 2:07 pm
I use Mach 3, and on occasions my CNC will just stop/freeze. I am told that is is a problem that Mach 3 does not like othe Electric motors being used with it. I have a Henry, that I use to collect my cuttings. Most of the time it works just fine, BUT if I am going a lengthy job it is likely just to "freeze". I gather this is a known issue. but that if I use a vaccum cleaner with a brushless motor I would have no problem I was equally told that the Mach Forum had messages about this problem. These I have been unable to find.
Does anyone else have the same issue, and is there a simple solution ?
Roskrow
Model of CNC Machine: GX-6060 CNC Router Table
Re: Mach & Problems with Other items such as a dust collecto
Postby Adrian » Sat Oct 29, 2016 6:57 pm
Generally if you're using vacuum cleaner on the CNC at the same time that it is cutting its the static electricity created from the dust moving into the nozzle and through that is the problem rather than interference from the motor itself.
Postby highpockets » Sat Oct 29, 2016 7:37 pm
Check your ground.
Make sure your computer, CNC and dust collector all have a "good" common electrical ground. It's amazing the number of mysterious problems that can be solved by a ground.
Postby martin54 » Wed Nov 02, 2016 9:07 pm
If your CNC has shielded cables then there shouldn't be any way an outside motor is going to cause problems with it running, if you are experiencing problems with the computer freezing I would look at other possible problems before investing in a different hoover :lol: :lol:
As the others have said a good earth is essential to prevent static problems, most of what I have read suggests using a star earth configuration so all earth wires run to one central point. Any cable shields should only be earthed at one end, earthing both ends will set up ground loops & cause you lots of problems.
It is worth pointing out that Mach3 doesn't play well with others so your control computer should be set up in such a way that other programs/apps don't start or carry out routine maintenance operations while you have mach3 running. Are you using mach3 with a parallel port or via USB/Ethernet ? The parallel port is probably the least stable of the 3 & most likely to be affected by other things going on.
My control computer runs mach3 & nothing else, there are no other programs installed on the machine, windows has been optimised for mach3 which basically means all the windows functions that go on automatically (in the back ground) have either been removed or disabled. The computer is never connected to the internet so there is no anti virus/malware software installed. I have been running mach3 like that for a couple of years or more using a parallel port connection & not had any problems at all, I run all sorts of other machinery at the same time as the CNC without probems. I have been meaning to upgrade to either a USB or Ethernet connection for quite a while now but only because it is generally considered to be a better set up, just never seem to have the time to get round to doing it though :lol: :lol: :lol:
