Return to point after accidentally hitting e-srop
Postby jdsmith1000 » Mon Jan 25, 2016 6:57 pm
I'm running my shark HD3 and accidentally hit e-stop. Please don't ask how, just did. How do I return to the point where the machine was when I hit the e-stop? Thanks, James
jdsmith1000
Model of CNC Machine: Shark HD 3
Re: Return to point after accidentally hitting e-srop
Postby Frunple » Mon Jan 25, 2016 9:03 pm
The machine should stop when you hit the Estop. Are you sure you have it wired correctly?
Frunple
Postby FixitMike » Mon Jan 25, 2016 9:38 pm
Which E-stop did you hit? Did you click on the one one the screen or the push the button on the controller? If it was the button on the controller, it cut power to the controller and you are out of luck. I've not used the E-stop on the screen.
I don't believe there is a way to return to where you were with the Shark controller. However, if you know the line number it stopped on, you can edit the G-code to remove the moves before it, rezero, and then run the new program. Probably easiest to add the wood to the fireplace pile and start over.
FixitMike
