Hi everyone!
Maybe some of you have had some experience with WinPC-NC software. I am trying to set up an High-Z S1000 milling router with CNC STEP Zero3 controller with some other auxiliary equipment, such as a manipulator arm, that should pass the material before milling, then give a signal to the router's controller to begin machining the part, and when it's finished, the controller (or PC) should pass a signal back to the manipulator to take the part away.
So the problem is the macros. How can I make the macros give and receive signals from the controller or PC?
