post
post
Postby john teichman » Tue Mar 26, 2013 12:10 am
my pp won't work in aspire 4 i use win cnc atc arcs inch works fine in 3.5 but not 4.0 any help on this from vectric i was wondering if i could drop the old file into 4.0 pp file but i don,t want to loose it.
john teichman
Re: post
Postby Adrian » Tue Mar 26, 2013 10:11 am
When you say it doesn't work what do you mean by that? Are you getting an error message? Is it producing invalid code?
If you're using a custom PP you will need to move it from the 3.5 to 4.0 location to be picked up.
Re: post
Postby john teichman » Tue Mar 26, 2013 11:25 pm
adrian i am in the middle of large job and could use 4,0 for shure can i just drop the win cnc file on the 4.0 file without danger of loosing it from 3.5 or can i use a copy to do it and drop it on the file with the same name?
john teichman
Re: post
Postby Adrian » Wed Mar 27, 2013 8:43 am
Safest way is to rename the one in 4.0 to something else and then copy (not move) the one from 3.5 over.
Re: post
Postby john teichman » Thu Mar 28, 2013 1:49 am
Adrian that did it thank you so much we must have altered the post some time ago and i forgot about it the old one works good John
john teichman
