windows 7
windows 7
Postby bluridg » Mon Mar 25, 2013 9:49 pm
recently upgraded my computer to a dedicated cnc computer. now using windows 7. several times when running a program, everything stopped. movement, router, movement on mach screen. reset button is flashing and red light on the gecko is on. anyone else had similar problems? could it be windows 7? any ideas? ted
bluridg
Re: windows 7
Postby Adrian » Mon Mar 25, 2013 10:08 pm
Have you disabled power saving features such as hard disk shutdown, usb disconnect, cpu slowdown etc?
Also worth checking that you don't have any automatic update processes working in the background.
Re: windows 7
Postby mike1966 » Thu Mar 28, 2013 2:40 am
Could be that the computer needs to be grounded to the machine, not jut the electrical ground.
My cnc machine was stopping every few minutes and it was a loose ground between the control box and computer
mike1966
Model of CNC Machine: shopmade 5axis
Re: windows 7
Postby zeeway » Thu Mar 28, 2013 11:29 am
mike1966 wrote:Could be that the computer needs to be grounded to the machine, not jut the electrical ground.
Amen to that. Was a problem for me also. But also make sure you take out all possible windows interrupts (program updates, etc.). Windows 7 works well for me.
Angie
zeeway
Re: windows 7
Postby bluridg » Fri Mar 29, 2013 12:51 pm
I am using the printer cable. thought it had grounds built in been running 2 1/2 yrs without grounding ted
bluridg
Re: windows 7
Postby bluridg » Sun Mar 31, 2013 10:27 am
evidently problem was caused by limit switches settings, although they hadn't been changed in two years. disengaged them and no more problems. now to find why. thanks everyone. will post what I find. ted
bluridg
