x.y problem
x.y problem
Postby sped1530 » Mon Dec 10, 2012 3:28 am
I have my board running or going long ways along the x axis in vcarve 5.5, but when I put it in mach3 the board runs up the y axis. What did I do or how can I change it in mach3?
sped1530
Model of CNC Machine: cast cnc joe 4x4
Re: x.y problem
Postby zeeway » Mon Dec 10, 2012 12:19 pm
In under Ports and Pins, you change the inputs for the X axis to become the inputs for the Y axis and vice versa. See:
http://www.jcopro.net/2012/02/01/swap-t ... ith-mach3/
zeeway
Re: x.y problem
Postby sped1530 » Mon Dec 10, 2012 3:24 pm
Thanks for the quick response.
But when I changed the x and y pins my A didn't work which is a slave to x.
I posted my pin settings, my controller is a g540.
any help would be greatly appreciated.
Dave
sped1530
Re: x.y problem
Postby zeeway » Mon Dec 10, 2012 6:53 pm
Try clicking on Config;/Slave Axis, and unslave your a. Close Mach3, then reopen Mach3 and reslave your A axis to whichever axis you choose. See if that works.
zeeway
Re: x.y problem
Postby zeeway » Mon Dec 10, 2012 6:57 pm
This is the way my ports and pins are set up....I also have a G540 and my A is slaved to X.
Angie
zeeway
Re: x.y problem
Postby sped1530 » Tue Dec 11, 2012 6:49 pm
zeeway wrote:This is the way my ports and pins are set up....I also have a G540 and my A is slaved to X.
Angie
That is the way I had it but if I had my board running left right or (along the x) in vcarve it would display and cut north south or (along the y) in mach3. I think I have something not clicked. Why do you have your y checked as dir low active?
Dave
sped1530
Re: x.y problem
Postby zeeway » Tue Dec 11, 2012 8:00 pm
Angie
Dave
Dave...sorry, I do not remember...but it works.
Angie
zeeway
