Z axis problem
Z axis problem
Postby pro70z28 » Sat Jun 23, 2012 4:32 pm
I've been having this problem for awhile but have always been too busy to get to the root of the problem.
Here's the problem, if I'm not supplying enough info. please let me know what else is needed to diagnose.
I set the "Z" height off the workpiece with the "Z" plate & the screen shows +1.00 when it's set. (I seem to remember that number used to be +.5" I think).
Then when I start the job (rough pass on a 3-d sign) the tool raises to +1.6", then heads to the first cut.
When it stops & the "Z" axis plunges it stops at +1.25" and starts an air pass.
I've tried everything I can think of to get it to make a cut, I have the tool cut depth set at .25"
My guess is I just have a setting messed up somewhere along the line but I can't for the life of me figure out what I did to change the setting.
Any ideas, or any missing info I can provide to get to the bottom of this.
I've got a couple 2'x6' cedar signs I really need to get out fast.
(of course this type of thing always seems to happen when I'm in a deadline situation)
Thanks in advance for any help you can provide.
I tried to post this in the ShopBot forum, but can't log in, been one of those days. :cry: I'm using the ShopBot software to cut the job. Machine is a ShopBot PRT96
pro70z28
Re: Z axis problem
Postby BrianM » Sat Jun 23, 2012 5:30 pm
Are you sure you have set z zero to the surface of the material in Aspire? this is the result I would expect if the job was programmed for z zero on the machine bed and the tool was zeroed at the material surface - I've done this in the past :oops: .
Brian
Brian Moran
Chairman
Vectric Ltd.
BrianM
Vectric Staff
Re: Z axis problem
Postby pro70z28 » Sat Jun 23, 2012 6:32 pm
I have to plead ignorance. I can't find a place to set the "Z" axis in Aspire doing a rough in pass.
That brings up another point though. When I do a profile cut I have the same problem. I've been getting by, by entering a negative value in the "Z" height box. If i leave it "0" it does an air cut just like it's doing with the 3-d pass.
pro70z28
Re: Z axis problem
Postby zeeway » Sat Jun 23, 2012 7:21 pm
When you set up your material size, there is a box to check that indicates whether you will be setting z to the top of your material or the bottom of the material (table top). Check to make sure you are setting the z to the same place checked in the material size screen.
Angie
zeeway
Re: Z axis problem
Postby pro70z28 » Sat Jun 23, 2012 8:01 pm
Thanks Brian & Angie, that was it. I figured it was something simple, but I looked right over that one.
I appreciate the help.
pro70z28
