Hello,
i search the installation exe file for the version Mach3 version 3.040.
This version is no more available on FTP site of Artsoft.
Please contact me if you can provide me this specific version.
Thank's
Fabrice
Search specific version Mach3
Re: Search specific version Mach3
You will find it on the FTP under legacy versions
Gary
My mistake its not there as you noted I will check my copies for you
Gary
Beckwith Decor Products
Custom CNC Tooling/Onsrud Distributor
http://www.beckwithdecor.com
- Model of CNC Machine: Sorotec PFE-1000
Hello Gary,
thanks for reply, unfortunatly, the FTP site start with version 3.042.020.
I hope you found this version in your archive.
Fabrice
Fabrice
- Mark
- Vectric Staff
Hello Fabrice,
If you require this specific version, I am sure that if you email Mach3 support,
they would be able to supply it for you.
I am not sure about the legality of you obtaining it from another source.
Cheers,
Mark.
Cheers,
Mark.
Fabrice
I checked my archives but did not have it, had 3.038 then jumped to 3.042.019 email Andrew at mach he should be able to send it to you.
Why do you want to go back to 3.040 (2008) rather than the current lock down?
Gary
Gary
Hello Gary,
here an answer i write to an other user here :
Thank's but i have 3.039 and 3.041, and as far i remember
the 3.040 was the first version that run with my portal cnc.
At this time the system was able to run a 8m/min, today with actual
Mach3 version only 3,5m/min. Higher the systeme loose steps and
i would rebuilt the initial config to test and find out the reason.
________________________________
Best regards,
Fabrice
Best regards,
Fabrice
Hello
until now i not found this version, so i try with 2.63
The CNC run well at 8m/min, but i need to test more
in situation.
I dont no if this is do by the // driver or something
other in Mach3 that not allow to leave run the machine
with higher speed that 3m/min in latest version.
Any idea ?
Fabrice
in situation.
Any idea ?
Fabrice
Hello,
some refresh, i search... follow actualy a thread in the Mach3 yahoo group
with similar issues (but reason can be an other).
Maybe that help me to found !
Fabrice
Fabrice
