i'm trying to find out if anyone has ever seen a 90 degree, 1/2 inch v carving endmill with either a 1/2" or 3/8" shank. a 3 inch shank would be nice.
thanks.
Looking for an endmill
- Model of CNC Machine: Techno LC4896 CNC ROUTER
Re: LOOKING FOR AN ENDMILL
i will thanks.
Re: Looking for an endmill
You might also try 'mcmaster.com' and 'mscdirect.com'. They (especially msc) have an almost unlimited selection of cutting tool profiles. They are primarily geared toward metal working, but I have used many of their metal working tools for wood.
Re: Looking for an endmill - mission update
Well I checked out Centurion Tools. They had what I wanted but when it came in the shape is something I am not use to seeing. Its a solid carbide .50 shaft
configured to cut a 90 degre V. There is no area for relief. A V bit for wood, like a Home Depot it has 2 blades welded to the body of the bit with open areas for chips to flow through. This bit is totally flat with the sharp carbide edges and thats it.
I will be testing the performance today and i'll post the results along with a photo of the tool later.
hello nappy
i found a company, an i have ordered from them...
they have good price, and also you can ask ANY type of tool..... they can make you if they have no in stock...
http://www.bqtool.com/
i'm sure they have you need, carbide or hss, solid or tipped...
thanks
viktor
thanks
viktor
Re: Looking for an endmill AND THE ANSWER ISSSSS
I just got done testing the new tool. It works fine. It cuts a clean v carve letter with no issues.
here is a photo of the tool.
Nappy1,
I have a couple of these bits from Centurion and how well they work depends on the material. For hardwoods you may have to adjust your feed rate and rpm as they will burn faster than your typical 2 or 3 flute v-bit. Another tip is to keep the cutting end clean and free of any buildup and to run an extra fine diamond file across the cutting surface in-between uses.
While I really like the spiral bits I've gotten from Centurion, I won't be purchasing any more of their v-bits.
Tim
Tim
I am using them on HDU so they are working well but I shart your opinion. Not for anything else. If they has a clearanced area in between the the cutting edges it would be great. This is what i am cutting.
