Either one would work. The one that stands proud would be done in Aspire and the other in VCarvePro. Of course, if you have Aspire they could both be done in Aspire.Greolt wrote:That is interesting. Do you mean a 3D grape vine that stands proud of the surrounding area or a vee carved grape vine, into an existing surface?rgoldner wrote: As long as the XY grape vine runs on the diagonal it can be wrapped.
Greg
The material size would be set so that its width is the length of your cylinder and its height is the circumference. In other words the area of the surface of the cylinder is set as the area of the material. Therefore, when the design is wrapped around the cylinder the material takes up all of the cylinder's surface area. I don't know if I'm making myself clear.
The actual design (the grape vine) is drawn on the diagonal. When it is wrapped around the cylinder it actually starts at one end of the cylinder and spirals around the cylinder to the other end.
Here's another way of looking at it. Take a 8.5" X 11" piece of paper and draw a line diagonally from one corner to the other. Wrap that piece of paper around a cylinder (or just use some scotch tape to turn it into a cylinder) that is 2.705" in diameter and 11" long. You will see that the line on the paper spirals up the cylinder and that the paper completely covers the surface of the cylinder. Anything that is drawn on the paper (or carved using Aspire or VCarvePro) is essentially transferred to the surface of the cylinder.
Let me know if this is clear or if I just muddied the water.
