Hi from Mike in need, indeed.
I am using VCARVE PRO.
Please, If I open a new file and make a setting (ie: I set the material depth and others) and I then move on to downloading and creating vectors and tool paths, which I am getting on pretty well with. Can I not flip back to the first opened window, and there alter my material depth or maybe material size?
I am having to open a new file and start all over again because I can't find a way back.
How green can this novice be? Laugh out loud.
Any help would be gratefully appreciated.
Mike the ancient one.
Depth Setting
Re: Depth Setting
Hi Mike,
If you click on Edit in the upper (horizontal) menu and look at the drop down box you will see a command that says either "Material Size" or "Job Size and Position". Select that and your initial setup box will re-open.
Tim
Tim
Re: Depth Setting
Hi Tim. Thanks so much for your help. Like I say: " A novice in need is a novice indeed.
My very best of wishes and gratitude.
From Mike
From Mike
