My machine for some reason is messing up. I upgraded to VCarve 5.0. Attacheed is my file without the machine code to make it smaller. I am using Mach3 latest stable build.
Everything was fine then one day any curve is a weavy curve instead of a normal rounded curve.
Anyone have any advice?
Problem with curves
- Model of CNC Machine: DIY
Problem with curves
- Wedding-Book-Test-001.crv
- (119.5 KiB) Downloaded 199 times
http://www.makemyownguitar.com
http://www.cncinside.com
Re: Problem with curves
If you're using Mach3 then try changing the IJ Mode to Inc instead of Absolute within the Mach3 Config>General Config menu.
I think VCarve 5 uses the Arcs post processors by default so you may not have seen this problem with the previous version.
