EMC/EMI filter question
Postby dan_barber » Sun Jan 06, 2019 9:40 pm
Does an EMC/EMI filter like https://www.valinonline.com/products/508-110 go before the VFD or after the VFD on the cable that goes to the spindle? Also, if I use a filter on the output side of the VFD, would this protect both the VFD and the motor?
dan_barber
Re: EMC/EMI filter question
Postby ger21 » Sun Jan 06, 2019 11:17 pm
Do not put ANYTHING between the VFD and the motor.
Check with the VFD manufacturer on what you should use before the VFD. Typically a line reactor is used.
ger21
