stepper motor replacement help needed
Postby swampies » Sat Sep 15, 2018 8:11 pm
I have decieded to replace my cheap chinese 3020 machine with a new build.
However I wish to use my current controller and Mach 3 settings as I still want to use my 3020 for fine work.
The steppers on the 3020 are nema 23's 57BYGH56-4017B x2 and a 57BYGH41-402B, Unfortunately I am not sure what steppers I can use to replace them and still keep the controllers settings.
The controller is a TB6600 stepper driver
The new machine will have a cutting area of 3ft x 2ft x 4inch
Any advice on steppers will be greatly appreciated as I dont have a clue about them.
Scott
swampies
Model of CNC Machine: unknown hobby machine
Re: stepper motor replacement help needed
Postby ger21 » Sat Sep 15, 2018 8:25 pm
To answer that properly, you need to provide details of the drive system(s), how much weight you are moving, and how fast you want to move it.
ger21
Postby swampies » Sat Sep 15, 2018 8:42 pm
Thanks for the reply,
However I can not answer that as the machine is still in the design stage and everything revolves around getting the equivalent steppers to the originals. I dont want to have to get a new controller as I am trying to build on the cheap.
So need to keep original controller and settings so as to not have to keep messing around changing settings when switching between machines.
I dont need a machine thats fast, just one with a bigger cutting area. I 'm sick of using an area of 8in x 10in.
I intend to use BallScrew and I think they are called linear supported rails.
swampies
Postby ger21 » Sat Sep 15, 2018 8:54 pm
Those motors appear to be about 2.8amps, 175oz-in.
So anything in the 2.5-3amp range should work.
These would be similar to what you have. https://www.automationtechnologiesinc.c ... duplicate/
ger21
Postby swampies » Sat Sep 15, 2018 9:10 pm
Could I use a 57bygh56-401
swampies
Postby swampies » Sat Sep 15, 2018 10:11 pm
I've also spotted these 23HS8430B which are dual shaft
Step Angle
1,8°
Rated Voltage
3.0 V
Rated Current
3.0 A
Phase Resistance
1.0 Ohm/Phase
Phase inductance
3.5 mH/Phase
Holding Torque
1.9Nm
Detent Torque
6.0 N.cm Max
Rotor Torque
480 g- cm²
Lead Wires
4
Shaft Diameter
6,35 mm
Motor Length
76 mm
Motor Weight
1,05 kg
Lead Connection
Back - A+, Green - A-, Red - B+, Blue - B-
swampies
Postby swampies » Sun Sep 16, 2018 10:30 am
I've had an ordering frenzy.
So far I have ordered :
2 x 1200mm supported linear rails 20mm
1 x 1200mm ballscrew 16mm
2 x 750mm supported linear rails 16mm
1 x 750mm ballscrew 16mm
2 x 200mm MGN12 linear rails
1 x 200mm ballscrew 16mm
3 x 23HS8430B stepper motors.
The MGN12's might be a little too small but I will wait until the 200mm ballscrew turns up and have a prototyping session.
swampies
