New controller for 5hp 230V Colombo Spindle?
Postby dan_barber » Sat May 12, 2018 3:31 am
I used to power 5hp 230V Colombo Spindle with 230V 3 phase, but I am running out of a residential garage now, so the AC Tech controller will not work. I assume I will need another controller.
I am not sure about 230v single and 3 phase, although from what I have read the 230v available in a residence will be single phase. Is there a way to power the spindle with 230V 1 phase or create 3 phase 230V from 230V 1 phase?
What controller unit can you recommend?
dan_barber
Re: New controller for 5hp 230V Colombo Spindle?
Postby IslaWW » Sat May 12, 2018 4:40 am
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby dan_barber » Sat May 12, 2018 2:45 pm
It turns out the controller I have can take either single phase or 3 phase. That's a big relief. I didn't want to spend money on a new controller. I'm a little unhappy that the spindle vendor used a lower horse power controller on a 5hp spindle. My assumption was that the controller would be 5hp as well. This is the controller that I have on my spindle. https://www.clrwtr.com/Products/ESV222N02YXC
dan_barber
Postby ger21 » Sat May 12, 2018 5:21 pm
dan_barber wrote:It turns out the controller I have can take either single phase or 3 phase. That's a big relief. I didn't want to spend money on a new controller. I'm a little unhappy that the spindle vendor used a lower horse power controller on a 5hp spindle. My assumption was that the controller would be 5hp as well. This is the controller that I have on my spindle. https://www.clrwtr.com/Products/ESV222N02YXC
It's called a VFD, or Inverter.
You're 5HP spindle will only be a 3HP spindle with that VFD.
ger21
