Tool height fluctuation during operation
Postby reanielaw » Sun Jan 28, 2018 12:06 am
Hey everyone,
I'm running a CNC router (Pacer 4010). I have been noticing lately that my tool height has been increasing and decreasing in height as I'm running a program. I thought my waste board was uneven but when I go to tool tip my bit, I'll be getting a lower or higher measurement than when I first measured it in the start of running my sheet. I'm not sure what would cause this. I thought maybe my bit is slipping a little bit inside the collet but I checked that and it was nice and tight. Could the cone be slipping down a little bit in the spindle? Has anyone heard of this and would happen to know the possible cause?
Thank you
reanielaw
Model of CNC Machine: Pacer 4010
Re: Tool height fluctuation during operation
Postby ger21 » Sun Jan 28, 2018 12:52 am
You mean the toolholder in an ATC? If it moved down, you'd know it immediately.
Are you sure the workpiece isn't moving?
ger21
Postby 4DThinker » Sun Jan 28, 2018 2:30 am
Check the coupler between the Z axis stepper and the Z drive shaft. If it is just a little loose then it may be the cause of your Z height woes.
4DThinker
Postby martin54 » Sun Jan 28, 2018 1:39 pm
While you are checking couplings you are as well checking the spindle is secure in the mount & the spindle mount isn't moving at all, how old is the machine ? have you checked for backlash or binding of the axis ?
Postby garylmast » Sun Jan 28, 2018 2:34 pm
An old collet could be and probably is the culprit. If that's not it, the stepper motor for the Z axis could also be the problem. If you are not losing height when using different sizes of mills (different collets), the stepper motor would be the next thing I would check. If that is, a quick solution could be adding springs to help hold the weight of the spindle. If that don't work, replacing with a higher torque stepper motor would be suggested.
garylmast
