Vacuum Pump
Vacuum Pump
Postby Ms Wolffie » Wed Nov 15, 2017 9:11 am
I am considering buying a 4x6 machine with vacuum table.
I made a mistake once and bought an inferior pump.
For this table they use 2 pumps.They sent me a photo of the label, as far as I can see, this is what it says.
2.2 Kw
50 Kz
155 m3/min
31 kg
220 V
2700 l/min
-34 Kpa
For those in the know, is that big enough?
TIA
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Re: Vacuum Pump
Postby cascayou » Sat Dec 16, 2017 4:06 pm
You might want to check with an electrician, I think it might run hot since we have 60 Herz in the US
cascayou
Model of CNC Machine: Axiom Elite
Re: Vacuum Pump
Postby PaulRowntree » Sat Dec 16, 2017 10:43 pm
cascayou wrote:You might want to check with an electrician, I think it might run hot since we have 60 Herz in the US
Wolffie is from a land down under ...
Paul Rowntree
PaulRowntree
Re: Vacuum Pump
Postby martin54 » Sun Dec 17, 2017 2:40 am
I take it the table is zoned so each vac pump covers half the table :lol: :lol:
Have you got a link if you are buying this from a company ??? :lol:
Oh good to see you back posting :lol:
