Router bit with fishtail tip
Postby kak » Wed Oct 25, 2017 7:19 pm
I have one of them, 3mm and I like it.
I only get one hit when I google "fishtail router bit".
The cutting edges are crossing like an X at the tip, so it's cutting with the shoulders.
Do you know another name for that bit?
kak
Model of CNC Machine: DIY CNC
Re: Router bit with fishtail tip
Postby Adrian » Wed Oct 25, 2017 8:03 pm
This question came up the other day. See my reply here - viewtopic.php?f=2&t=28339&p=204852
Postby ger21 » Wed Oct 25, 2017 8:42 pm
2 flute upcut spiral router bit.
ger21
Postby Leo » Wed Oct 25, 2017 8:54 pm
Actually I did not know such a geometry was available. It's new to me. I don't know how long this has existed.
I googled Router Bit with fishtail and a lot popped up.
Interesting, I will try this over the winter.
www.leosworkshop.com
Leo
Postby Rcnewcomb » Wed Oct 25, 2017 9:21 pm
Be aware that these are fine for profile cuts but for pocketing they can tend to leave swirl marks on the bottom of the pocket.
Postby Leo » Wed Oct 25, 2017 10:02 pm
Ohhh, I am very much aware that this is NOT a good geometry for a nice smooth flat bottom.
For hole making where the hole size is controlled via circular interpolation is where I see something this.
Nice smooth flat bottom pocketing is another whole process discussion.
Leo
Postby scottp55 » Fri Oct 27, 2017 4:08 pm
Very good for CLEAN sidewall cuts, and leaves a little "tooth" on pocket bottoms for gluing dense oily woods. Seem to have a cleaner top edge with less splintering, and very clean bottom on drill throughs/cutouts. I only have used the .117" though from here;
http://www.precisebits.com/products/carbidebits/precisebit-soft.asp
scottp55
