Vhipe super PID speed control
Postby Kevin Jenness » Wed Aug 30, 2017 2:57 pm
I recently became aware of this aftermarket speed controller and am considering putting one on my Camaster Stinger with a PC 7518 router. Has anyone used this in a similar application? Do you recommend it? Any pictures available?
Kevin Jenness
Model of CNC Machine: Camaster Stinger II SR48
Re: Vhipe super PID speed control
Postby ger21 » Wed Aug 30, 2017 3:14 pm
I've been using one with a porter cable 690 for many years. Mine is actually a pre-release version I received for testing. It's an excellent speed control for anyone using a router.
However, they aren't cheap, at about $175 delivered. Imo, a better option is to go to a 2.2kw chinese spindle and VFD, which you can get for about $325, provided you have 240V available.
But if you want to stick with the Porter Cable, yes, the Super Pid is a great upgrade.
ger21
Postby Kevin Jenness » Wed Aug 30, 2017 4:55 pm
ger21, thanks for the response. The spindle upgrade sounds attractive, but I am not a circuithead and am not sure how easy it would be to adapt the 240V feed to my control box. I am pretty sure that retrofitting a spindle and controlling the speed through WINCNC is beyond me (the process was described at length by an engineer on the Camheads forum). No doubt having an external vfd and just turning the spindle on and off through WINCNC would be simpler. Can you suggest a reliable source for such a spindle/vfd?
Kevin Jenness
Postby ger21 » Wed Aug 30, 2017 6:49 pm
I can tell you where I got mine, but can't guarantee how long it will last. I've only bench tested it so far, but people have been buying from this seller for a very long time.
http://www.ebay.com/itm/FOUR-BEARINGS-2 ... 1203446783
ger21
Postby highpockets » Thu Aug 31, 2017 12:26 am
I've had one on my CNC router since day one. Really like the fact that it adjusts the current to the router to maintain the set speed. Only down side is shipping from Australia is expensive, but Val has always given me great tech support and even shipped me a new sensor no charge when we thought the existing one had gone bad.
On the road so no pictures.
Postby vgraves » Thu Aug 31, 2017 1:47 am
I also have one controlling my PC 7518, and it works great. You just have to modify the router to accommodate the speed sensor. I put mine in a box with a remote display panel. Normally, router speed is controlled by the gcode, but I can also control my speed manually. Once my router dies I may look into the spindle option, but for my hobby needs, this setup works well.
vgraves
Model of CNC Machine: CNC Router Parts PRO4848 w/LinuxCNC
