Maslow
Maslow
Postby highpockets » Mon May 22, 2017 3:34 pm
Ran across this site last night, have no idea what I was researching at the time :D :D :D http://www.maslowcnc.com/
It will not replace a high end CNC, but it's fun to see what can be accomplished on the cheap. Interested to see where this goes in the near future.
Re: Maslow
Postby Adrian » Mon May 22, 2017 3:54 pm
Can't quite get my head around how it cuts without being deflected but it obviously does, presumably it's shallow cuts and the bricks stop it being pushed/pulled. For what it's intended for it looks like a really interesting piece of kit.
Re: Maslow
Postby kp91 » Mon May 22, 2017 4:07 pm
Now that they have a z axis add-on, that could be a great shop helper for breaking down sheet goods into rough components. Load a sheet, let it run while you work on something else.
Neat idea.
Doug
1 John 1:9
Fredericksburg, VA
kp91
Model of CNC Machine: Digital Wood Carver
Re: Maslow
Postby highpockets » Mon May 22, 2017 6:24 pm
Doug, my thoughts exactly. Seems like it would work for breaking down a 4x8 sheet and if you didn't need anything more accurate than a 64th it might just do for a finished project.
Anyway, I thought is was an interesting idea.
Re: Maslow
Postby adze_cnc » Tue May 23, 2017 5:14 pm
Adrian,
Shallow cuts and really slow cutting: https://youtu.be/05W4egqLVEM?t=1m18s (starting video at 1:18 shows actual speed)
adze_cnc
Re: Maslow
Postby Tundraman » Wed May 24, 2017 1:31 am
Based on one of the video's it cuts at 25 ipm.
If it's breaking stuff down while you're doing other things it's not so bad. Howevr, do you have to manually adjust the cutting depth for each pass? That would slow things up a bit.
Tundraman
Model of CNC Machine: Techno Isel 3'x4' Gantry III
Re: Maslow
Postby highpockets » Wed May 24, 2017 11:29 pm
They now have a Z axis for $60 from what I've read.
Re: Maslow
Postby glas-ifanger » Fri Aug 30, 2019 5:47 pm
ich habe eine Maslow cnc
erste versuche sind zu sehen auf
https://www.youtube.com/watch?v=Bq4oNMe ... e=youtu.be
gruss kurt
http://www.kifanger.ch/
gruss kurt
http://www.glas-ifanger.ch/
glas-ifanger
Model of CNC Machine: gall and maslow
