Water Cooled Spindle - Water Pump
Postby Leo » Sat May 20, 2017 5:25 pm
I am finding that the water flows through only at a trickle. It was better than that when new.
I have cleaned with CLR, blown out with air and even disassembled top of spindle to clean out passages.
I am suspect of the pump, loosing it's newness.
Has anyone run into this situation and how did you solve the issue.
www.leosworkshop.com
Leo
Re: Water Cooled Spindle - Water Pump
Postby bravesoul » Sat May 20, 2017 6:23 pm
Leo,
If it is similar to an aquarium pump, you might want to take the front of pump apart and check that the body that is attached to the rotating vanes are clean. I have to take mine apart and clean out that area with a small round brush and be sure that the vanes are clean too.
Joe
bravesoul
Model of CNC Machine: ShopBot PRT ALPHA 48"x96"
Postby garylmast » Sun May 21, 2017 12:11 pm
On one of the machines I bought, they forgot to send it with a pump. I first tried the 264 GPH submersible pump from Harbor Freight, and all I got was a trickle. I changed it to the 620 GPH one and it worked good. The pump is 120 volt and my cnc is 220 volt, so I wired the pump to one of it's legs, so it turns on when the machine is turned on.
garylmast
Postby Leo » Sun May 21, 2017 12:31 pm
I did take the pump apart and pulled the magnet shaft out. I cleaned inside the pocket that the magnet shaft fits into and I cleaned the vanes. I also lubed the shaft ends.
Gary, yes like an pond pump. I went to Home Depot and got a couple of small pumps, but they were too small. The bigger one was around 450. I could try a bigger one, but I am hoping to find an impeller pump or a much better centrifugal pump.
I don't think anything is blocked or clogged, just need a little pump pressure.
Leo
Postby martin54 » Sun May 21, 2017 4:07 pm
How have you got things set up Leo ? Don't forget as well as a decent flow rate you will need a pump that is capable of a decent lift if your set up is anything like mine. I have a 25 litre container that sits on the ground so I need at least a 4 foot lift from the pump to the actual spindle :lol: :lol:
I just bought a pond pump that supported a water feature to ensure I had sufficient lift.
I don't actually get a huge flow rate from my system but temperatures here are not generally that great anyway so it hasn't been a problem, even on a very long job the spindle has never really got hot regardless of the speed it has been running at.
Postby Leo » Sun May 21, 2017 5:20 pm
Perhaps a decent pond pump would be sufficient. I am just a little perplexed that I had some relatively flow in the beginning but not now.
If I put air pressure in the lines to blow out the water is blasts out.
I found a diaphragm pump on Amazon that cane pump 100PSI
https://www.amazon.com/dp/B0166UVLKU/_e ... K6C5BK5JZQ
It's NOT a lot of money and if I am going to get a pump anyway it seems to be a good direction to go.
There was one occasion where my spindle got a little warm, certainly not hot, but I was in a many many hours long run.
Maybe the diaphragm pump will lot stand the longevity of time, but it's a worthy test.
Leo
Postby 101179567skltd » Fri Jan 05, 2018 3:50 pm
How did this pump work?
101179567skltd
Model of CNC Machine: Home Made 24x36
Postby Leo » Fri Jan 05, 2018 4:22 pm
At the end of the day I decided that the pump was not the issue. Well now I have a few pond pumps for when I make a pond.
The problem was that the water passages in the spindle were plugged up and restricting flow.
I ended up taking the spindle apart. It was NOT an easy task - not at all. There were 2 tiny "O" rings that got distorted and blocked flow. I replaced the "O" rings and the flow returned to normal. The spindle works but it's not as quiet as when new. I may have damaged the bearings a little. I don't really have the "right" equipment to disassemble and reassemble.
I also bought a new spindle. I now have the new spindle on the machine and the original spindle as a backup.
I am still using the original Chinese pump - it's actually a pretty good pump.
Moral of story and a couple of take aways
1) KEEP THE WATER ABSOLUTELY CLEAN - even filter it.
2) DO NOT use caustics - CLR - Drain cleaner - Draino - anything like that. The spindle is aluminum and those things are not good for aluminum.
3) a little automotive antifreeze is a good thing
4) Use distilled water
5) KEEP THE WATER ABSOLUTELY CLEAN - even filter it.
6) KEEP THE WATER ABSOLUTELY CLEAN - even filter it.
Leo
